三峽 2009-04-05 18:49:22 | 重慶市 其他專業(yè) | 1571查看 14回答
監(jiān)理合同簽訂后是先編規(guī)劃還是先組建監(jiān)理機(jī)構(gòu)
(14)
已采納監(jiān)理合同簽訂后是先編規(guī)劃還是先組建監(jiān)理機(jī)構(gòu) 回答:先組建監(jiān)理機(jī)構(gòu)
2009-04-05 21:36:51
監(jiān)理合同簽訂后是先編規(guī)劃還是先組建監(jiān)理機(jī)構(gòu)?回答應(yīng)該是先根據(jù)監(jiān)理大綱編制規(guī)劃后,確定組織機(jī)構(gòu)然后再組建監(jiān)理機(jī)構(gòu)!
2009-04-07 18:42:51
先有機(jī)構(gòu),再有規(guī)化
2009-04-06 16:17:21
監(jiān)理合同簽訂后是先編規(guī)劃還是先組建監(jiān)理機(jī)構(gòu) 答:先編規(guī)劃,后組建監(jiān)理機(jī)構(gòu)
2009-04-05 18:52:22
監(jiān)理投標(biāo)時(shí)要報(bào)監(jiān)理機(jī)構(gòu)組成情況,但只是個(gè)初步的,具體人員組成應(yīng)該是中標(biāo)后組建,故先編監(jiān)理規(guī)劃再組建監(jiān)理機(jī)構(gòu)
2009-04-05 19:00:22
按常規(guī)監(jiān)理合同簽訂前監(jiān)理機(jī)構(gòu)以建立,監(jiān)理合同簽訂后根據(jù)工程項(xiàng)目內(nèi)容、規(guī)模編制監(jiān)理規(guī)劃。
2009-04-05 20:02:46
監(jiān)理機(jī)構(gòu)應(yīng)該在監(jiān)理投標(biāo)的時(shí)候就組建好,應(yīng)該是現(xiàn)組建監(jiān)理組織在編制規(guī)劃
2009-04-05 18:51:15
監(jiān)理合同簽訂一般是先先組建監(jiān)理機(jī)構(gòu)后編規(guī)劃。
2009-04-05 18:52:15
按常規(guī)監(jiān)理合同簽訂前監(jiān)理機(jī)構(gòu)已經(jīng)存在,監(jiān)理工程中標(biāo)后,由監(jiān)理公司簽訂監(jiān)理合同,監(jiān)理公司的技術(shù)負(fù)責(zé)人,根據(jù)工程項(xiàng)目內(nèi)容、規(guī)模編制監(jiān)理規(guī)劃后,根據(jù)監(jiān)理規(guī)劃組建項(xiàng)目的監(jiān)理機(jī)構(gòu)。
2009-04-06 09:17:26
監(jiān)理合同簽訂后是先編規(guī)劃還是先組建監(jiān)理機(jī)構(gòu) 答:現(xiàn)實(shí)中,你還是先組建監(jiān)理機(jī)構(gòu),再編規(guī)劃吧!祝你成功!
2009-04-06 09:17:31
監(jiān)理合同簽訂前,監(jiān)理機(jī)構(gòu)已經(jīng)組建了,監(jiān)理合同簽訂后,編制監(jiān)理規(guī)劃,
2009-04-07 09:34:33
組織監(jiān)理完成后,有這個(gè)監(jiān)理組織進(jìn)行編制監(jiān)理規(guī)劃,然后進(jìn)行審核通過后實(shí)施
2009-04-05 21:40:50
按常規(guī)監(jiān)理合同簽訂前監(jiān)理機(jī)構(gòu)已經(jīng)建立,監(jiān)理合同簽訂后根據(jù)工程項(xiàng)目內(nèi)容、規(guī)模編制監(jiān)理規(guī)劃。
2009-04-05 22:32:08
應(yīng)該是監(jiān)理公司先編好規(guī)劃后,再組建該項(xiàng)目的監(jiān)理機(jī)構(gòu).
2009-04-06 07:26:51
