chengyp 2008-12-05 14:58:51 | 重慶市 其他專業 | 26641查看 13回答
c250*75*20*2 c180*70*20*2 每米重量是多少 謝謝r
None
(13)
已采納型鋼 c250*75*20*2每米重量是8.23Kg/m c型鋼 c180*70*20*2每米重量是4.44kg/m. 有一個小程序<截面特性>可以計算。很方便的。 1,槽80x40x15x2.0,80,40,15,2,14.52,33.6,347,341600,77900,462,112900000 2,槽100x50x15x2.5,100,50,15,2.5,17.06,39.4,523,813400,171900,1090,352800000 3,槽120x50x20x2.5,120,50,20,2.5,17.06,40.3,598,1294000,209600,1246,660900000 4,槽120x60x20x3.0,120,60,20,3,21.06,48.7,765,1706800,373600,2296,1153200000 5,槽140x60x20x3.0,140,60,20,3,19.64,46.1,825,2454200,394900,2476,1589800000 6,槽150x50x20x1.6,150,50,20,1.6,15.24,27.2,422,1362930,141870,360,663830000 7,槽150x50x20x2.0,150,50,20,2,15.24,27.2,528,1703660,177330,700,629790000 8,槽150x50x20x2.5,150,50,20,2.5,15.24,27.2,660,2129580,221660,1380,1037230000 9,槽150x50x20x3.0,150,50,20,3,15.24,27.2,792,2555490,266000,2380,1244530000 10,槽150x60x20x1.6,150,60,20,1.6,19,45,451,1514130,214620,390,995870000 11,槽150x60x20x2.0,150,60,20,2,19,45,564,1892660,268520,750,1244840000 12,槽150x60x20x2.5,150,60,20,2.5,19,45,705,2365830,335650,1470,1556050000 13,槽150x60x20x3.0,150,60,20,3,19,45,846,2838990,402780,2540,1867260000 14,槽160x60x20x2.0,160,60,20,2,18.41,44,582,2195200,274190,780,1417250000 15,槽160x60x20x2.5,160,60,20,2.5,18.41,44,728,2744000,342730,1520,1771660000 16,槽160x60x20x3.0,160,60,20,2.5,18.41,44,874,3292800,411280,2620,2125880000 17,槽160x70x20x3.0,160,70,20,3,22.24,52.5,742,3736400,604200,2836,3070500000 18,槽180x60x20x2.0,160,60,20,2,17.33,42.1,619,2861760,284520,830,1804350000 19,槽180x60x20x2.5,160,60,20,2.5,17.33,42.1,774,3602200,355650,1610,2255440000 20,槽180x60x20x3.0,160,60,20,3,17.33,42.1,926,4322640,426780,2790,2706520000 21,槽180x70x20x2.0,180,70,20,2,21.1,50,687,3439300,451800,870,2554750000 22,槽180x70x20x2.2,180,70,20,2.2,21.1,50,752,3749000,489700,1254,2856540000 23,槽180x70x20x2.5,180,70,20,2.5,21.1,50,848,4202000,544200,1710,3193430000 24,槽180x70x20x3.0,180,70,20,3,21.1,50,983,4730880,609240,2950,3832120000 25,槽200x65x20x2.0,200,65,20,2,18.1,44,673,3850560,353370,900,2693490000 26,槽200x65x20x2.5,200,65,20,2.5,18.1,44,842,4813200,441720,1760,3366860000 27,槽200x65x20x3.0,200,65,20,3,18.1,44,1010,5775840,530060,3030,4040230000 28,槽200x70x20x2.0,200,70,20,2,20,44,727,4400400,467100,920,3185500000 29,槽200x70x20x2.2,200,70,20,2.2,20,48,796,4798700,506400,1200,3548520000 30,槽200x70x20x2.5,200,70,20,2.5,20,48,898,5382100,562700,1800,3981870000 31,槽200x70x20x3.0,200,70,20,3,20,48,1037,6027840,629540,3120,4778240000 32,槽220x70x20x2.5,220,70,20,2.5,19,46,910,6263600,539850,1900,4877150000 33,槽220x70x20x3.0,220,70,20,3,19,46,1092,7516320,647820,3280,5852580000 34,槽220x70x20x3.2,220,70,20,3.2,19,46,1165,8017410,691000,3980,6242670000 35,槽220x75x20x2.0,220,75,20,2,20.8,51,787,5744500,568800,1290,4109230000 36,槽220x75x20x2.2,220,75,20,2.2,20.8,51,862,6268500,617100,1760,4609302000 37,槽220x75x20x2.5,220,75,20,2.5,20.7,51,973,7037600,686600,1950,5707180000 38,槽220x75x20x3.0,220,75,20,3,20.7,51,1119,7621240,761170,3360,6848620000 39,槽220x75x20x3.2,220,75,20,3.2,20.7,51,1194,8342660,811910,4080,7305200000 40,槽250x70x20x2.5,250,70,20,2.5,17.6,44,978,8441830,560030,2040,6427600000 41,槽250x70x20x3.0,250,70,20,3,17.6,44,1174,10130190,672040,3530,7713120000 42,槽250x70x20x3.2,250,70,20,3.2,17.6,44,1252,10805540,716840,4280,8227320000 43,槽250x80x20x2.5,250,80,20,2.5,21,51,1024,9098080,766550,2140,8721010000 44,槽250x80x20x3.0,250,80,20,3,21,51,1229,10917690,919850,3690,10465300000 各行數字含義(以最后一行為例): 槽250x80x20x3.0: 截面高度H=250mm; 截面寬度B=80mm; 卷邊寬度C=20mm; 厚度t=3mm; Y軸距離z0=21mm; 偏心距e=51mm; 截面面積A=1229mm2; 慣性矩Ix=10917690mm4; 慣性矩Iy=919850mm4; 截面模量Wx=87342mm3; 截面模量Wy=15591mm3; 回轉半徑ix=94.3mm; 回轉半徑iy=27.4mm; 抗扭慣性矩It=3690mm4; 扇形慣性矩Iw=10465300000mm4; 單位重量=A*7850/1000000=9.648Kg/m;
2008-12-05 15:12:45
C型鋼 c250*75*20*2每米重量是6.62kg/m C型鋼 c180*70*20*2每米重量是5.39kg/m
2008-12-05 17:43:49
查了一下: c型鋼 c250*75*20*2每米重量是6.62kg/m c型鋼 c180*70*20*2每米重量是5.39kg/m
2008-12-05 18:27:59
C型鋼c250*75*20*2 6.62KG/m C型鋼c180*70*20*2 5.39KG/m
2008-12-05 22:54:16
2008-12-05 15:05:36
c250*75*20*2 每米6.908 公斤 c180*70*20*2 每米5.652 公斤
2008-12-05 15:08:05
c250*75*20*2每米重量是;6.62kg/m. c180*70*20*2 每米重量是;5.39kg/m.
2008-12-05 15:08:27
C250×75×20×2.5是卷邊冷彎槽鋼,又稱C形鋼。對應的尺寸是高度×寬度×卷邊高×鋼板厚。它的重量是8.23Kg/m(這是理論重量,各生產廠家的產品與此稍有不同),這種型鋼一般常用于輕型鋼屋面及墻面的檁條。其它型號的重量你可查看《門式剛架輕型房屋鋼結構技術規程》(CECS102:2002 )附錄C。
2008-12-05 15:10:04
c250*75*20*2 重量是7.06kg/m c180*70*20*2 重量是5.65kg/m
2008-12-05 15:13:28
我只查到了c型鋼 C180*70*20*2每米重量是5.39kg/m,C250*75*20*2 表上沒有,也不好用插值的方法,可以用 黃金搭檔 給的公式計算。 從以上回答看,版本都不太一樣,你可以備一本五金手冊或《門式剛架輕型房屋鋼結構技術規程》(CECS102:2002 )附錄C,共使用時查詢方便
2008-12-05 15:31:58
c250*75*20*2 c180*70*20*2 C型槽鋼每米理論重量計算式為 W=0.00785*D*[H+2.24*(B-D)] H-高度 B-腿寬 D-腹厚
2008-12-05 15:40:37
你可查看《門式剛架輕型房屋鋼結構技術規程》(CECS102:2002 )附錄C。 C250×75×20×2.5的有是8.23kg/m c180*70*20*1.6的是4.44kg/m 給你個參考表再
2008-12-05 15:47:56
c型鋼 c250*75*20*2每米重量是8.23Kg/m;c型鋼 c180*70*20*2每米重量是4.44kg/m.在軟件里面可以查得到
2008-12-05 16:34:28
